HI,
Would anyone know if a game console can be set up and connected to the VGC-VA1, I am unfamiliar with the programs that came with this PC.
I have connected the cable to the composite port but none of the programs seem to get access to view it.
(I have a PCV-V1/G which uses Gigapocket and had no problems setting it up.)
Any help would be great, Thanks for reading.
You can do it, but you'll notice a delay
Hi Kee-Lo, would you know what software to use? Thanks.
Select an external source in VAIO Zone
I found that the ps2 looked pants through my system, and its no slouch.
Hi Jumpsuit,
I like to ask which program/software you used?
I don't seem to have VAIO Zone as kee-lo suggest.
Thanks.
Have you made your recovery DVDs yet?
Hi whsvaio, I used Giga Pocket explorer because I have a coaxial aerial input in the back of the Vaio.
Yup, the Recovery DVDS been made.
My VGC-VA1 does not come with neither Vaio Zone nor Giga Pocket explorer.
I've tried Intervideo Home Theater 2, it works but theres no sound
