HI,
Would anyone know if a game console can be set up and connected to the VGC-VA1, I am unfamiliar with the programs that came with this PC.
I have connected the cable to the composite port but none of the programs seem to get access to view it.
(I have a PCV-V1/G which uses Gigapocket and had no problems setting it up.)
Any help would be great, Thanks for reading.
Is this a Windows Media Centre box?
it comes with Windows Media Centre.
Can you select an input in TV mode?
Unfortunately not . It would have been much easier if it came with Giga Pocket.
For a PC that's just came out, I would have thought that it comes equipped with everything, especially with softwares to view devices plugged to the composite port
