Browser problems
miche_love_you
Browser problems
I seem to have a strange problem.
See, recently Internet Explorer has stopped working on my Vaio. After that Opera (the one I use the most) stopped as wel, saying that it can't connect to the server. And 2 day's ago Firefox started doing the same thing. But my internet connection is perfect! MSN messenger works fine and the browser in LimeWire works as well. But I don't want to stay stuck with that so I used System Restore. I restored my computer to a point ten day's ago. In the beginning IE worked again, Opera and Firefox didn't. But I was happy enough with that. So I shut my computer down yesterday evening. But now, when I started my computer up again, IE doesn't work anymore either! I'm now using the browser in Windows Media Player.
I have no idea what could have caused this. I only know that Opera stopped working after I had installed a new version of it (9.60).
If anyone has any insperation as to what the cause is or where the problem might be...
Thanks.
rich912
Hi miche_love_you,
From what you describe malware comes to mind....
If it is the case then you will need specialist help and I suggest that you post your problem on the Hijackthis forum
Go n-éirí an bóthar leat
