Can you help please?
I have trawled through the TV and the Laptop user guides and am more confused.
What is the best way to connect the equipment so i can watch movies from my laptop hard drive on my TV?
Is there a single cable i can buy that will do the trick?
Many thanks
Peter
Hi Peter and welcome to Club Vaio.
You are one of the lucky ones! You have a choice of connection.
Your FE31Z and your Bravia DL-32V2500 both have S-Video and VGA (PC 15-Pin) connections. Unfortunately neither of these carry sound, so you will also need an audio cable.
You Need:
3.5 mm jack to RCA sound cable - LIKE THIS
AND
S-Video to S-Video cable - LIKE THIS
OR
VGA Monitor Cable - LIKE THIS
Many thanks.
It was as I suspected - there is no single cable solution.
Is there any difference in picture quality by using the VGA or the S-Video cable
You have been a big help, best regards
Peter
