Hi !
I have installed Vista Ultimate in my VGN-S5M and i can't modify the brightness of my screen ! And also the S1 and S2 buttons doesn't work....and i have installed the Vaio Update and...it's unable to find the typical page of the automatic updater !
What can I do !?!? Thank you very much.....
nobody knows nothing ?
Pleaseee
http://www.vaio-link.com/downloads/select/select.asp?site=voe_en_GB_cons&category=0&serie=VGN-S&m=20...
Download and install:
Sony Shared Library
Sony Utilities DLL
VAIO Event Service
Install them in the right order as this is important!!
1. Sony Utilities
2. Sony Shared Library
3. Vaio Event Service
4. Setting Utility Series (Listed in the 'Other' tab)
Thank you very much for the answers but this is the first thing that i do and i doesn't works.....what can i do then ?
Thanks....
