SONY VISUAL COMMUNICATION CAMERA HELP!!! VGN-VCC1
moneybanks
Hey guys i really need help!! Its probably a very simple problem but i just cannot work anything out! Basically i have just bought a SONY VAIO VGN-BX297xp. The laptop is awesome no probs. BUT....when i access the motion eye camera (sony visual communication camera) the picture that comes up is very dark. I do not know how to change the settings, i am having quite a lot of trouble and its very annoying. Does anyone know how to change or adjust the settings so i can get it a little brighter? The camera is a sony visual communication camera vgn-vcc1. Any help would be very very appreciated.
Also i have seen people writing about a VGN-VCC2 type camera..? is this downloadable and where can i get it....?
moneybanks
Jesus christ!!! 83 people veiwing and no **** replies!!!! Thanks for everything guys!
michael81
Hy Moneybanks,
which Software do you use the camera with? Ususally as soon as the camera is accessed, there should come the sw camera utility up, you can set the brightness there... If you use skype or the camera capture utility, there are setting buttons. You can set the brightness there as well...
Hope this helps. Or else, post a screenshot? :smileygrin:
greets, michael
