converting
Descyciede
converting
just moved out a,d bought a new pc, downloaded the sonicstage 4.3, but it keeps on converting the database???????
plz help....
4 REPLIES 4
chris_lewis
Hi Descyciede, welcome to Club Vaio :slight_smile:
The database converter takes a while, took a couple of hours it had to do 5000 odd songs in my case but just let it do its thing. Even if you have cancelled the operation mid way thru it normally just keeps running, although it could need a reinstall if its hanging.
HTH
C
Descyciede
hi
thx for the suggestion,
kept my pc "converting" for 2 days, no result, reinstalled sonicstage, no result
:slight_frown: :slight_frown: :slight_frown:
anymore suggestions :smileyd_oh:
chris_lewis
Hi, have you checked to see if SS can get online? you may need to check the allowed list on your firewall or set it to learning when doing the reinstall. Just incase leave the player disconnected from your PC until SS is working too.
C
Descyciede
Re: converting
checked it and it gets online,
its been converting since yesterday,
still no results
