DOWNGRADE VISTA TO XP IN VGN-NR11Z
MILLIONFISH
HELLO I HAVE JUST BOUGHT A NEW VAIO AND I DONT LIKE THE VISTA , I HAVE TRIED TO INSTALL XP BUT XP CANT SEE THE HARD DISK. I WOULD BE SO THANKFULL IF I COULD GET SOME HELP AND DRIVER FOR MY MACHINE
THANKS A LOT.
7 REPLIES 7
profile.country.pt_PT.title
V57...
The Xp can't see the hard disk because they are in Raid 0...
Try this...
http://support.vaio.eu/os/xp/downgrade/index.asp?site=voe_en_GB_cons
MILLIONFISH
I FIND DIFFICULTIES TO LOG IN… IS THERE ANY OTHER POSSIBLE LINK TO DOWN LOAD THE DRIVERS..
THANKS AA LOT FOR YOUR REPLY!
V57...
I d'ont tihink so...
Sony haven't (yet) support fot xp in this model...
And I think you have another problem...only the Xp Pro with the Sp2 recognize the 2 processors...
V57...
MILLIONFISH
I HAVE INSTALLED THE DRIVERS AND XP WINDOWS FIND THE HARD DISK... BUT AT THE END OF THE SET UP... AT A POINT WERE XP CONFIGURE THE SYSTEM IT STAYS STABLE DOESN’T MOVES ON … I TRIED SOME OTHER OTHER COPIES TOO. I THINK I HAVE TO MOVE BACK TO THE VISTA 😞
larrybolt
MILLIONFISH, could you please send me the link to the drivers for the setup?
I'm not getting respond from LodgeN. I'm having the same problem by the way.
v.57, I called vaio support and they told only vista will run on my type of laptop, and when I started about Linux he said I had to forget about it. But, I did installed Debian successfully on my laptop yesterday.
I guess there are drivers aviable but I just need to find them.
MILLIONFISH
I HAVE INSTALLED THE DRIVERS ONLY FOR THE CHIPSET TO GET XP INSTALLED WITH A USB FLOPPY DISK.. I HAVE DOWNLOADED ftp://ftp.vaio-link.com/pub/OS/XPDOWNGRADE/FZ19/DRIVERS/ THE 1 SATA DRIVERS OR SEE http://club.vaio.sony.ru/clubvaio/RU/ru/forum/viewthread;jsessionid=35937B3E8089712632FA0DDD65F76A23...
