Drivers for Motion Eye 0n VGN-FW31E
dafterfader54
Hi There, have done an OS install from scratch but cannot find anything for the Moyion Eye also in device manager it says  drivers are needed for base system device, have not got aclue what that is can anyone help please?
Regards
Clive
rich912
Hi dafterfader54,
Your model uses Windows native drivers for the built in camera. Is there a USB camera listed in Device Manager under Imaging Devices or any unknown device with a yellow warning symbol? If so update the driver for this device within Device Manager using the ‘Have Disk’ method – the folder to point to is C:\Windows\inf.
The base system device will be a card reader – possibly the Memory Stick reader. You will find the drivers here:
http://www.sony.co.uk/support/en/product/VGN-FW31E/updates
Rich
Go n-éirí an bóthar leat
rich912
Hi dafterfader54,
Rich
