DVD region
nutty.neno
DVD region
Hi all i have a vgn-nr21z/t vaio with a AD-7560A ATA dvd rw drive dose anybody know if it can be changed to multi-region as a i have lots of dvds that wont play thanks in advance for any info.
Neno
Thalamus.
Champion
Hi nutty.neno,
you can change the region code of your DVD drive a fixed number of times, usually 5, unfortunately once you've made the fifth region change your drive will be locked to that region. There are region free software/firmware fixes scattered across the web but they do not always work.. :slight_frown:
nutty.neno
Ok thanks will have a search about.
Neno
Thalamus.
Champion
You're welcome.. :slight_smile:
