How to open DVD reader without any session ?
menton67
my laptop doesn't start anymore... It seems that "boot.ini" file has been corrupted (after "partition magic" use...)
windows does not start anymore. And I cannot open the dvd reader to put a bootable CD. (It seems to me that it can be opened only when you have open a windows session)
So what can I do ?
1/ use a trick I don't know yet (to learn) to manage to open the dvd reader, and then put a bootable cd in it (such as windows cd) and then correct the corrupted file (boot.ini) ?
2/ take out the hard drive and put as a slave on another pc and correct the file suposed to be corrupted ?
What are your ideas ?
5 REPLIES 5
profile.country.de_DE.title
seb21__
There is a tiny hole at the drive. This is a button.
    So, You have to take anything thin thing
    then stand up and say the words VAIO VAIO GIVE ME FEVER
    then turn around 3 times
    jump 2 times
    then say the words VAIO VAIO ZAP-ZAP-RAP
    and then put anything thin thing into the hole.
that should open the drive. But be quite:smileyshhh: Its a special VAIO trick.
kee-lo_
Seb
Too many beers?
seb21__
well, i had a long night.:smileyblush:
kee-lo_
Hehe
I was just reading the original post, thats why I don't suggest PM, it destroys PCs (In my opinion anyway)
menton67
thanks for the information.... it seems it was well-known ....!
i repared my pc ....
