Hi Guys and Gals
Can anybody tell me how to remove some light scratching from the area at the side of the touch pad on my FE41S tried toothpaste and its still there.
Any Ideas
Regards
Atticmaster
Hi atticmaster,
I would be careful as trying to remove the scratches may make the damage worse..
Hi atticmaster,
Hi atticmaster,
something like the Keyboard protectors from ProtecT I guess would do the trick, use the following link to view: ProtecT Keyboard Protectors
I'm not sure if they ship to the UK though..
Hi atticmaster,
You're welcome..
Hi
I managed to get hold of some clear sticky back film from a local sign writer, so when I get my Vaio back from the Sony repair centre I will cut-out a panel to stick over the front of the keyboard
Regards
Atticmaster
That's a cheaper option..
