When using the WEB button on my Vaio the keyboard has recently become disabled. It is fine when using computer normally. Does anyone have a suggestion as to resolving this issue?
Solved! Go to Solution.
Do you have a USB Mouse plugged in?
This may conflict with the keyboard and should be disconnected when using Quick Web Access.
Wow you're sharp - Instant solution! I had got used to the USB bluetooth plug being there and removing it did the trick. Many thanks.
