Keyboard locked / disabled when using WEB only function
rodowne21
When using the WEB button on my Vaio the keyboard has recently become disabled. It is fine when using computer normally. Does anyone have a suggestion as to resolving this issue?
Do you have a USB Mouse plugged in?
This may conflict with the keyboard and should be disconnected when using Quick Web Access.
:thinking:
:thinking:
rodowne21
Wow you're sharp - Instant solution! I had got used to the USB bluetooth plug being there and removing it did the trick. Many thanks.
