Laptop won't hold charge - time for a new battery?
shellbells
Hi there,
my laptop has recently stopped holding its charge. When running off battery power alone it will last for about 20mins and shut down
I now have to have it permantely powered to the mains
When I power I'm now told the battery performance is 'critical' - I'm sure now I need a new battery
Question really is do I buy an original Sony Vaio battery or source it online (another brand/ manufactuer)
- Last time I bought a replacement Vaio charger (previous laptop) it shorted the battery and needed to run off a permanent charge
Thanks for any help/ tips/ suggestions!
Shelly
rich912
Hi Shelly,
Judging from the number of reports on this forum from members that have experienced problems with none Sony batteries, especially thoses that require BIOS alterations, the safe option is a genuine battery.
They don't come cheap but you will usually find reasonably priced genuine batteries on Amazon.
Rich
Go n-éirí an bóthar leat
