Hi All
My Sony Vaio VGN-G11VN came with a lovely brown leather cover that velcroed to the base of the laptop with little square pads and used clear double sided non marking sticky pads to attach to the back of the screen.
The lasted a year or so and gave up when I was travelling in Thailand (probably the heat was a factor).
So since then I can't use it! Which is a real shame as it is a really nice case and looks really quality... so my question is: Where can I get replacement sticky pads?!
I've looked everywhere I could think of but come back blank... any suggestions really appreciated!
Matt
From what you said, I would suggest to call Customer service so they could check on their database if this is really indeed available.
Hi Matt,
Try a DIY store. They are readily available.
Rich
