Lost VGC-RA204 recovery discs, where to find downloads?
chickenpie
The downloads section hasr drivers and original vaio software but not the recovery discs. Am I missing something obvious?
Tags (1)
Thalamus.
Champion
Hi chickenpie,
welcome to Questions & answers..:smileyhappy:
Unfortunately the recovery disc's and the applications that came pre-installed on your Vaio are not available to download..
You  can however, if you wish, purchase a set of recovery discs from Vaio  support which should allow you to restore the original Vaio supplied OS  and applications..
You can find the contact details for vaio  support by either clicking  Support at the top of this page or by using  the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then next Select Model..
Then click Log-In
Once logged select Get In Touch.
Then Click on the Out of Warranty tab, then Phone support.
Thalamus.
Champion
Hi chickenpie,
Then click Log-In
