I tried to acess word starter 2010 but it now says that there is a problem with the licence. I followed the troubleshooting suggestions ,but nothing works. I did not purchase this it was already installed on my laptop. Any suggestions??
Thanks I will try that. Hopefully that will work.
Hi scarson70,
You haven't detailed what troubleshooting you have tried, but assuming that the programme is available for reinstall under Vaio Recovery Centre > reinstall Programs or Drivers, then try uninstalling via Control Panel and then reinstall from Vaio Recovery Centre.
Rich
Good luck and let us know how it goes...
Rich
