Modem not working on VPCS12V9E 3g vodafone
willjones76
Hi
I recently purchased a VPCS12V9E and am having issues getting the internal 3g modem working on it.
I have a 3g sim from Vodafone and have inserted it.
When I use the supplied webtogo software it just says "no device found".
When I use the latest vodafone software it sees the modem, but it wont let me click the "enabled" checkbox.
I have tried removing and reinstalling the drivers and all software. I have restarted the modem in control panel.
I've run out of ideas! ANy suggestions?
Thanks in advance
Will
5 REPLIES 5
Hi Will,
Have you turned the WWAN on in Vaio Smart Network?
There is a Sony Tutorial for your model here: -
http://genesis.sony-europe.com/instranet/ccil_sony/selfservice/search.jsp?DocId=51144&l=en_GB&m=VPCS...
It goes through the activation process in detail.
:wink:
willjones76
Yes its switched on in Vaio Smart Netwrok.
Interstingly though, if I switch it off there, it wil not allow me to switch it on again. A very similar symptom to what I see in the vodafone software.
Yes I followed that tutorial. Notice this text in it:
If your VAIO comes preinstalled with WebToGo® OneClick Internet, you can use this generic connection manager with any SIM card from any mobile operator. Alternatively, you can use the Windows 7 Network Connections to set up your WWAN connection.
I have already described that "When I use the supplied webtogo software it just says "no device found"."
If I use the windows 7 connection device I get the error "Eror 678"
Its like al the software doesnt accept that the modem is installed and working somehow
Wil
Hmm ... Seems a bit of a mystery.
Is it a brand new sim card?  Has it worked before?
I noticed this other question: -
https://www.sony.co.uk/discussions/message/545238#545238
:thinking:
willjones76
Sim has worked for 12 months in its dongle and in the internal slot in my previous Samsung.
I don't think its a SIM issue - the software is having issues switching on, or identifying the modem.
I guess it is time to contact Vaio Support to see if they can check if the modem is faulty.
:slight_frown:
