My keyboard has stopped working - Help!
thegingerprince
Hi folksThe keyboard and trackpad on my Sony Vaio PCG-7181M laptop have stopped working, I've had to attach a USB keyboard to the laptop to be able to use it - can anyone out there help me?
Tags (2)
Probably best to have a word with one of Sony's Service Partners near where you live.  A full list of Service Partners in the UK can be found here: -
http://support.vaio.sony.eu/computing/vaio/contacts/asc.aspx?l=en_GB&m=VGN-NW21ZF_S
:slight_frown:
4 REPLIES 4
I cannot tell what features your Vaio has because you are quoting an invalid model.  Have a look on the screen surround for the correct model which will start with VGN- or VPC-
Some models have the facility to turn off the trackpad in Vaio Control Centre but as your keyboard has stopped working also, it is likely that a cable has become disconnected and you will need a repair.
Is your Vaio still within warranty?
:thinking:
thegingerprince
Ah ... the model is VGN-NW21ZF.
I am no longer in warranty afraid.
:slight_frown:
Virfierro
I bought a VAIO but
Very often when typing the letters they don't appear on the screen or they come later, or I need to click the cursor to start to type again. All this make my work so slow.
Can anyone help? thanks
