Sometimes the screen goes blank. Then it shows a lot of writings in blue colour and turns itself off, so quick that I can't read what it says. The computer restarts. When finally it is re-booted, I get the massage saying it is recovered from a serious problem (Windows message). My biggiest fear is that one day the computer will die on me and will never wake up. Can anyone tell me what is wrong with my computer? I would appreciate your help.
Yeah we need some clues to solve the case....
It would be handy to know what computer you have as well, plus what you are doing when it restarts.
On my Computer : I think it's a driver-problem with directX.
I have a Vaio PCG-FR315S and when I push down the graphic quality give it no problems. But when I push up the quality ---> "CRASH"
Well theres your answer, keep the quality low. Your GFX chipset wont be able to handle complicated graphics, thats why it crashes.
Seb: Install the latest version of Directx from microsofts website (reinstall if you already have the latest) and update your graphics card drivers.
You may also afterwards want to run the directx tests to see if they bring up errors. Type dxdiag in the run dialogue box on the start menu then just run the tests.
I have directX 9.0c and I have installed the latest graphics-driver
But not only my Computer is crashing by "URU Complete Chronicles"
A friend from me have a Desktop Computer with a PCI-Express Graphicscard from ATI.
And his Computer crashed or freezing too.
The problem is the Software. There is incompatible to the graphics driver.
Yeah but the relief is that it's not your card thats at fault, it's poor programming
Right!:smileydancing:
You could wait for a patch for the game, or what would probably be more useful to the game makers is if you reported the problem to them.
Thats a good idea.
Warum bin ich nicht selbst darauf gekommen?:smileyconfused:
No new patches!:smileycry:
But thanks.
