Sometimes the screen goes blank. Then it shows a lot of writings in blue colour and turns itself off, so quick that I can't read what it says. The computer restarts. When finally it is re-booted, I get the massage saying it is recovered from a serious problem (Windows message). My biggiest fear is that one day the computer will die on me and will never wake up. Can anyone tell me what is wrong with my computer? I would appreciate your help.
Thank you. Now I have turned off the auto-restart option. When it happens next time, I will read the message and will post it for you to have a look.
My laptop is PCG-FR415S. When the computer is re-booted, it is not any different from normal, except I get this "Your computer has receovered from a serious problem." message. As advised, I have turned off the auto-restart option, so when it happens again, I will be able to read what it say on the screen.
i have the same probleme with my fr 415s!
when i use an adapteur usb to serial,sometimes it works,sometimes it reboot:smileyconfused:
windows says its a probleme with graphique card or drivers (ati igp 345m).i didn t found an upgrade for my card?but i m not sure it will fix it!
if it s can help here are the error message from windows:
signature de l erreur:BCCode : 100000d1 BCP1 : 00000060 BCP2 : 00000002 BCP3 : 00000000
BCP4 : F768DEE7 OSVer : 5_1_2600 SP : 2_0 Product : 768_1
information tecniques supplementaires:Error Message: STOP 0x000000EA THREAD_STUCK_IN_DEVICE_DRIVER (Q293078)
Analyse:
Un pilote de périphérique installé sur le système est à l'origine du problème, mais nous ne pouvons pas déterminer la cause précise de celui-ci.
En Francais:
Message d'erreur : STOP 0x000000EA THREAD_STUCK_IN_DEVICE_DRIVER
N° d'article:293078
Dernière révision:lundi 27 septembre 2004
Version:1.0
Ancien nº de publication de cet article : F293078
Sur cette page
SymptômesSymptômes
CauseCause
RésolutionRésolution
ContournementContournement
Plus d'informationsPlus d'informations
Symptômes
L'un des messages d'erreur Stop suivants peut s'afficher :
STOP: 0x100000EA THREAD_STUCK_IN_DEVICE_DRIVER_M
Cause
Ce problème peut se produire si le pilote d'affichage est pris dans une boucle infinie, dans l'attente du passage à l'état inactif (veille) de votre matériel vidéo. Ceci est généralement le signe d'un problème au niveau du matériel vidéo ou indique que le pilote d'affichage est dans l'incapacité de programmer correctement le matériel.
Résolution
Pour résoudre ce problème, procurez-vous, puis installez le pilote le plus récent pour votre carte graphique ou remplacez cette dernière.
Contournement
Pour contourner ce problème, procédez comme suit :
1.Cliquez sur Démarrer, sur Panneau de configuration, puis double-cliquez sur Affichage.
2.Sous l'onglet Paramètres, cliquez sur Avancés, puis sur l'onglet Dépannage.
3.Déplacez le curseur Accélération matérielle sur Aucune, puis désactivez la case à cocher Activer la combinaison d'écriture.
4.Cliquez sur OK à deux reprises.
Remarque Cette procédure empêche le pilote d'affichage de programmer le matériel de façon incorrecte ; toutefois, elle entraîne la perte d'une partie des fonctionnalités et des performances vidéo. Même si vous pouvez toujours définir l'accélération matérielle sur un niveau supérieur à Aucune pour regagner en fonctionnalités et en performances, ces paramètres augmentent les risques de voir le problème se reproduire. Pour assurer une stabilité optimale, laissez l'accélération matérielle désactivée.
Plus d'informations
Ce message d'erreur Stop peut également survenir dans les pilotes de cartes graphiques qui ne représentent pas un périphérique physique. Il peut, par exemple, s'afficher dans le pilote de carte graphique virtuelle utilisé par Symantec PCAnywhere. Si PCAnywhere est installé sur un ordinateur sur lequel ce message d'erreur s'affiche, reportez-vous au site Web de Symantec pour savoir s'il existe des correctifs disponibles pour votre version de PCAnywhere.
Les produits tiers mentionnés dans le présent article proviennent de sociétés indépendantes de Microsoft. Microsoft exclut toute garantie, implicite ou autre, concernant les performances ou la fiabilité de ces produits.
Les informations contenues dans cet article s'appliquent au(x) produit(s) suivant(s):
¿Microsoft Windows XP Professionnel
¿Microsoft Windows XP Édition familiale
¿Microsoft Windows XP Édition 64 bits
thank tou very much for your help,but i already tried this,but it s still reboot!!!:smileycry:
Damn.....
