Please... PLEASE
some one tell about where can I get XP
help about which product are compatible with XP.
Cheers, regards
Please... PLEASE
Cheers, regards
I have vaio FE41 : and stupid vista
Can I reboot xp on this?
Or how can I rid out this stupid vista?
Cos , most of the program and attachment arent work, and some of them are block.
Regards............
There are a few possibilitys you can go with
1) You stick with Vista & the Vaio apps
As it come pre-installed your recovery partion will also have Vista on
2) You Can clean install with XP
This means you would loose the Recovery Partion along with the VAIO Applications to which you will not be able to get back
3) You can cross your fingers in hope that is you do clean install someone on here may know of compatable drivers from another VAIO system allowing you to use the VAIO apps.
4) If number 3 works run to your local computer shop & purchase the latest Acronis True Image 10 & then create a image of your system exact after XP & the relevent drivers are in place & keep it well safe.
Hopefully someone may know of the drivers
You can buy XP from any computer store, like Amazon
2) You Can clean install with XP This means you would loose the Recovery Partion along with the VAIO Applications to which you will not be able to get back
