Hi Guys,
Hopefully someone will be able to help with this issue - currently banging my head against a brick wall! : )
I'm using a Sony Vaio VGN-Z21WN, and have recently had a local computer store install a brand new copy of Windows 7 Professional. Previously was running Windows Vista business.
All was working fine, then all of a sudden when booting up, the wifi wouldn't connect and the message 'Not Connected - No Connections available' appears when hovering above the WAN tray icon (which now also has a big red cross in front of it.
If I leave the laptop off for say a week without turning it on, the connection comes back - then after rebooting, the same issue comes back. Really annoying!!
The LAN works fine, and can run the internet fine when plugging in to the broadband router.
HELP PLE EE A AASE! : )
Solved! Go to Solution.
Hi jaykay84,
welcome to Questions & answers..:smileyhappy:
It's dificult to know what your local store have done when installing Windows 7 pro on your vaio..
There are a selection of drivers available from the support site so I would suggest you contact the local computer store an explain your problem & point them in the direction of the avaible windows 7 drivers for your vaio, hopefully they can resolve this for you..
Hi jaykay84,
