NW20SFS RESTORE C DRIVE
BOOFLE
I did a restore c drive as i was having problems with error messages, now my D data drive has gone can anyone help on device manager there is C drive and something called system reserved any help much appreciated
Hi BOOFLE and welcome.
It sounds like you have carried out a complete recovery back to factory settings and anything you have added since new may be lost.  Did you make a backup of your programs and data before doing the restore?
Recheck in Computer Management: -
Start -> Right-click 'My Computer' -> 'Manage' -> Disc Management
You should see a Recovery Partition, a C:\ Drive and a system reserved section for the Quick WEB Access.  Is there anything else?
:thinking:
BOOFLE
Hi had a look at dics management this is what it says DISC 0  C HEALTHY 288.55 GB then9.44 healthy recovery partition and system reserved 100mb underneath it says disc 1 removable drive D at the side. Am i better off taking it to the shop thank you
