RE:SCREEN JUST GOES BLANK....
Poesface
Hi Guys,
Got this 10.1 inch vaio "vpcm13m1e" and you cruise the net for half hour then suddenlyu the screen goes blank!!!
has this happened to anybody and if so is there a fix,apart reconfiguiring the dam thing which over the phone with sony ive done,it took me 1 and a half hours but still the problem remained?!!?
any suggestions would be great!!
thanks!!
Poesface
Tags (2)
11 REPLIES 11
rich912
Hi Poesface,
If by 'reconfiguring' you mean a reset to factory settings, and this hasn't cured the problem then it would seem to be hardware related.
Is it just the screen that turns off or does the machine shut down? If just the screen going blank what do you have do to get it displaying again?
Have you checked the processor temperatures with a utility such as PC Wizard?
http://www.softpedia.com/get/System/System-Info/PC-Wizard-Release.shtml
Rich
Go n-éirí an bóthar leat
Poesface
a real bad answer thx but no thx,timewaster!!
rich912
Thanks for those kind words Po faced (sic) always nice to know that the efforts of fellow forum members is appreciated.
Rich
Message was edited by: rich912
Poesface
soz mate,im just speakin my mind,soz!!
pooface
Thalamus.
Champion
I do wonder why you asked your question on a user forum if you are not prepared to answer the simple questions from a dedicated user who was trying to assist you..
Probably your best option would be to contact the official Sony Vaio support line using the number that can be located via the Contact Sony support page..
rich912
pooface
That speaks volumes about the way your mind works.
Poesface
sorry agin to all,i apolagise,really!!
thx to all for the advice so far!!
im greatful!!
thx
Poesface
tx very much k,im new here,forgive me,thx for the advice!!
KatherineYH
I had the same problem with my laptop. On power on the screen would stay black, no POST, nothing at all on the display. The HDD would spin up but the HDD indicator would not come on and would not boot. The DVD drive would spin up and attempt to read a disc if one was in the tray but still would not boot. I found an answer on another forum. Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot. It worked for me! Just shutdown, put the battery back in you're good to go. Worked for me so definitely worth a try.
_______________
Life is too serious to be taken seriously https://imagicon.info/cat/12-13/text-smiley.png
Copy/pasted from http://en.kioskea.net/forum/affich-24155-laptop-screen-blank-when-switched-on
Edited to provide source of copy/pasted answer from another forum
