VPCEE2E1E
Lana13
VPCEE2E1E
The problem is that the Wireless LED switches off unexpectedly and suddenly without doing anything. The switch is physically on but the LED is not lighted and hence it cannot detect any wirless connections.
rich912
Hi Lana13,
If this is happening when on battery power check that the wireless device has not been set to allow the computer to turn off the device to save power.
Control Panel > Device Manager > expand Network Adaptors > Right click the wireless device and select properties > Power Management tab.
Rich
Go n-éirí an bóthar leat
Lana13
Thanks Rich - it worked first time!
rich912
You're welcome Lana :slight_smile:
