Hi all! I'm done!! i mean i've been serching drivers for this model for 4 h in driver support section and couldn't find! Is there any other name of this one. and please post the link where i can download! thx in advance!
Message was edited by: -Cass-
Solved! Go to Solution.
Hi 4iller,
You are trying to search using the chassis model number which can be shared by several product models. Have a look on the screen surround or in Vaio Control Center > System Information for the model name.
Rich
Hello Rich,
Thank you for response! Yes, you were right - it's located on the lower right corner of the screen.. It was dark in my room when i was checking it And PCG-61715V is VPCCA!
All drivers downloaded and installed successfully!
Regards!
4iller
You're welcome 4iller:smileyhappy:
