TMODAlpha
PCG-F400 Battery
When i charge my battery while switched off it never stops charging, it never boots from the battery, in windows it charges to 100%, when i remove it and replace it, it resets to 0% it also does this if i shut down but not restart, it does this in both battery port 1 and 2. Ideas anyone?
TMODAlpha
Anyone?:smileysad:
jammold
Hi TMODAlpha.
It looks like your charging circuits on your PC are defective, and as a consequence the laptop conveniently overcharges the battery.
You should get this seen to by VAIO Link as soon as possible.
BTW: It is frustrating when a post is not answered but be patient and we will answer your post as soon as we can and to the best of our knowledge.
TMODAlpha
ok thanks
