After the last update to my Vaio VGN-CR11S with Windows Vista yesterday the power meter disappeared from the task bar. How do I get oit back?
Hi Lassijuhani,
welcome to Club Vaio..
if you click on the < ( show hidden icons) in the task bar does the power meter icon reappear?
If not go to Start and type Taskbar into the search box, then click on Taskbar And Start menu.
A new Taskbar And Start menu window should open, select the Notification tab and check that Power is selected.
