Can anyone help with PrtSc?
I have tried using the PrtSc key to copy my screen image onto a blank Word page. When I open the Word page and select paste, instead of the screen image copying I always get a small black blob created. It seems to make no difference as to what I try to copy (eg a pdf page or anything else on the screen), the result is always the same. I have also tried Ctrl with PrtSc, and Fn with PrtSc, and Alt PrtSc, all without success.
The laptop is Sony Vaio VPCSE (Home 7) and only 1 month old. I have never had this problem on other computers, and my old Dell (XP) works perfectly in this respect.
I have tried all advice from Google search pages regarding this, and in frustration am trying this discussion forum - really hope someone can help!
Could it be the PrtSc key is not correctly linked to the function, and if so can it be corrected?
Hi BrownToad,
See whether there is anything of help in this link.
http://www.buzzle.com/articles/print-screen-not-working.html
Rich
Thanks Rich for the link. I eagerly tried everthing in that link, and nothing worked. The snipping tool produced exactly the same tiny black blob, instead of the image selected.
I will try to contact Sony via their chatline (if they have one).
Does your Vaio have a "Fn" key available beside the Windows key? Use it with the Print Screen button. If not, try using a screen capture software and see if your Print Screen button will work.
