Problems with external display on VAIO Z1
smanger
i have a vaio pcg-z1xsp, and i bought an external tft monitor to plug into it and increase my workspace.
however, the monitors native resolution is 1680x1050 (widescreen) but i can't set my laptop to output that resolution. it will do 1600x 1200, but there are no widescreen setting available to me.
at first i thought it may be because the latops gfx card only had 16mb of ram, but then i worked out that 1600x1200 is actually higher than 1680x 1050.
so does anyone know if there is a way i can manually set the resolution or is it just plain not possible with this laptop?
KurtBonfield
The Graphics Card simply won't do the mode you are asking it to do.
See ATI link below: -
http://mirror.ati.com/products/embedded/mobilityradeon/features.html
smanger
thanks for the reply!
that sucks. anyone want to buy my laptop?
