Hi there!
First let me excuse for my bad english. Its been a long time, since i used it. :")
I have a Problem with my new Vaio VGN-FE41M. I'm trying to use my webcam for skype and it doesnt work. Sometimes it works and sometimes not. Frustrating.
There is the message "No favored videosource found." (My translation - org. : "Keine bevorzugte Videoquelle gefunden")
I already tried "SplitVideo" but it doesnt work.
Thank you for your help!
Hi nikolaus-online and welcome to Club Vaio.
Your English is a lot better than my German (or is it Belgian - there is a Bocholt there as well I think)
There is a problem with the webcam when using Vista - we have reported this to Sony and we are waiting for a fix.
Hopefully soon .............
Hello,
yes my english is bad too im from Germany and have the same Vaio Notebook with Skype and the same Problem with the Webcam:-)
I hope iu can get an Update!!!
Thanks!
This sounds like that problem with Vista where the motion eye only works once per session due to bad drivers.
I have a second Notebook.
On this Notebook is installed.
And this integrated Webcam works.
So i think this is not a Problem with Windows, it is more a problem with the Drivers.
So Sony Vaio have this automatically Tool named "Vaio Update", why the not upload new drivers for this problem ?
same problem and same notebook here.
at least it keeps ppl from seeing my ugly mug... :smileygrin:
Hi there,
Hallo zusammen,
sorry, dass ich in Deutsch schreibe, scheint mir doch ein Problem der deutschen VAIOs zu sein.
Habe dasselbe Notebook, Vista Home Premium, und hatte das selbe Problem. Habe es folgendermaßen behoben. NICHT (!) das Vaio-Capture-Utility starten. Nur Skype und dort den Video-Button nehmen. Die Kamera kann nur von einer Instanz angesprochen werden. Hoffe, dass ich helfen konnte.
Now in english:
do not use the "Vaio-Capture-Utility", because this cam can only work by one process. Close all programms, which used the cam and then start Skype, push the video-button and it shoult works.
Hope this was helpfull,
Tino
Hi there,
Hallo zusammen,
Now in english:
Tino
@mgrasek
dass der Treiber nach Nutzung eines Programms das die Camera anspricht auch wieder mittels dieses Treibers die Camera wieder deaktiviert und der Treiber dann ruht, bis ein anderes Programm darauf zugreift.<<
genau das macht er doch auch.
Ich wollte im ersten Post meinerseits nur meine Erfahrung kundtun. Hier ist immer nur vom Problem mit Skype die Rede, also geh ich davon aus, dass die Kamera ansonsten funktioniert. Wenn ja => "RtfM" Seite 44,
Wenn nicht => VAIO-Update nutzen,
Keep Smiling,
Tino
