Processor udgrade?
tomdam
Processor udgrade?
Hi everyone, I have had my vaio for some time and its got to that stage where i want to upgrade a few things. I have already upgraded my RAM to its max (8GB) but was wondering if its possible to upgrade my processor from core i5 to i7? (model VPCEB4X0E)
Many thanks for an answers
Tags (1)
besbeqa20
yes u can upgrade to i7 if it supported the i5 so far. just make sure u buy the right one for your cpu socket. check the manufacturers website to get the info about your model first
besbeqa20
tomdam
Thank you very much for your answer it will help me gre a t l y :smileygrin:
