profile.country.el_GR.title
hadjista
sd driver for vgn-n31z
i installed windows 7 on my vaio model vgn-n31z and the driver for sd is lost. can any one help me with this please?
thanks
rich912
Hi hadjista,
Try installing the original Vista driver that you will find in the original drivers package.
http://www.sony.co.uk/support/en/product/VGN-N31Z_W/downloads/Preinstalled_Drivers_2775
You will need to update the driver for the device from within Device Manager using the Have Disk method:
Extract the files from the installation package to a known location.
Click Start > Control Panel.
Double click Device Manager.
Right click the device and select Properties
Click the Driver tab.
Click Update Driver.
Click Browse my computer for driver software.
Click Let me pick from a list...
Click Have Disk....
Click Browse and navigate to the folder where you placed the extracted files.
Click OK.
Click Next.
Click Finish.
Reboot your system if requested.
Rich
Go n-éirí an bóthar leat
rich912
Hi hadjista,
Click Have Disk....
Click OK.
Click Next.
Click Finish.
Rich
