Slim cover for VPCZ21C5E
migonza21
I am looking for a slim cover for my new VAIO VPCZ21C5E but I cannot find any.
I found this one instead for VAIO VPCZ21V9E...
http://www.sony.co.uk/product/p61-slip-covers/vgp-cvz3#pageType=Compatibles
Are those two VAIOs the same model but perhaps different colour?
Thank you.
Tags (3)
Thalamus.
Champion
Hi migonza21,
I would have thought that the VPCZ21 series would you the same chassis so I would guess the case should fit your model, however to be 100% sure it may be worth visiting your local Sony Centre & see if they have one in stock you can try..:smileywink:
Thalamus.
Champion
Hi migonza21,
migonza21
Thanks for that Thalamus.
I am finding information on Sony's site quite confusing and going to a local store to see if they got a cover is kind of an adventure and time consuming for me, but as you suggest, that would be the best thing to do given the circumstances.
Thanks.
Thalamus.
Champion
HI,
If I had to give a yes or no answer then I would say yes it's a 99% chance that the slip that you've found on the Sony site would fit your Z21..
I normally like to see & feel what the case/covers look like before making the purchase..
