Vaio VPCEB1J1E gets stuck and needs to restart to be fixed?
illazar
Hi guys,
my Vaio is only 1 and a h  alf years old, and i have this wiered problem. My pc gets stuck when i watch movies, talk on skype use web browser or watch youtube. Once it gets stcuk I continuesly press ctrl+alt+del and after a minute or so it gives control to the keyboard and opens taskmgr but after 2 - 3 minutes again the same problem and sometimes I have to restart the computer because the ctrl+alt+del will not work. I have tested the hardware as much as I can and everthing looks fine no errors what so ever, then i thought it is a virus and to try out I formated the computer but still the same problem. I have updated everything and all drivers seem to be ok. Anyone had the same problem? I ahve tryed to isolate it but no luck. If anyone has suggestion on what to do else in a week I will take it with the warenty to the shop but since I am an IT guy I think there is better chance i fix it my self although if it is a hardware issue I will give it to them. Thanks for any help.
0 REPLIES 0
