- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
hi
after having fallen to the ground my fz29vn has a dark image, almost black with no shine, just can see some shadows bur when i turn it on a other monitor or in tv its all ok.
Maybe some bulb damage or some conection?
its expensive?
thanks
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
yes the cause could possibly either a faulty Inverter, backlight bulb or cabling problem, however as you dropped your vaio it may be any number of things..:smileysad:
Maybe worth contacting one of Sony's authorised repairers.
Tto find contact details for Sony Vaio support..
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Then Click on the Out of Warranty tab to locate the nearest location.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Then click Log-In
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Fortunately, it was the inverter. Just open the LCD frame and plugged one of the two connections that were disconnected. Problem solved.
Here is one link of a tutorial that can help:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Excellent, glad you were able to fix your vaio..:smileyhappy:
