sony camcorder ro sony vaio
ellie57
How can i get the sound recorded by the camcorder recorded on to the cd also? When recording is captured I keep being asked which music file I want to included. I don't I just want the background noises recorded with the pictures
5 REPLIES 5
KingGeorge
Sounds like you should just use other software... Many vaio's come with adobe premiere elements, in which you can do pretty much everything you want, non professionally.
The DV gate plus utility also just captures the recorded material as it is on the tape, I think...
Greetz
kee-lo_
Premiere Elements is not a bad package in it's price range
jumpsuit
Pinnacle has also been recommended to me.
TheMackster
Ulead Video Studio.. Probably one of the best and most easiest for the "Non" tech head beginners out there.
real easy user interface, coupled with some of the most "Budget" Advanced features you can find in a package for it's price range
did some video footage from paragliding not so long back and got them online.. what i have done doesn't even come close the extended possibilities of this video capture and editing suite, but you can see some of the results :
1st : http://www.ckskool.co.uk/video/glidertracked.wmv
2nd after a little more practice : http://www.ckskool.co.uk/video/999.wmv
ellie57
Thanks all, will try your solutions
