sony vaio VGN-CR31s
Crazy_Nutter
sony vaio VGN-CR31s
hello everyone
i have come to have a sony vaio VGN-CR31s and i have been trying to register it but the register page doesnt recognise my model :slight_frown: is there a way i can register?
i am trying to get some recovery disks for it as the recovery partition is gone :slight_frown:  to contact support for disks i have to be logged on via serial and i cant do that because i cant register it,
any ideas?
rich912
Hi Crazy_Nutter,
As the notebook is over one year old you cannot use the online registration system. You will need to call the out of warranty number to both register and order a set of recovery disks.
From the UK the number is 0905 0310006 (£0.35/min)
Rich
Go n-éirí an bóthar leat
rich912
Hi Crazy_Nutter,
Rich
Crazy_Nutter
Do u know how much they are in uk pounds?
rich912
I’m not entirely certain of the current price but I believe it is approx £50.
