hi there ! is it possible to upgrade cpu in SONY VAIO VGN-FS215E ?
i would like to replace an Intel Celeron M 370 with an intel T2300 Core duo
Solved! Go to Solution.
Hi rinderkind and welcome.
Check it out for yourself, but I think your 915GM Express chipset does not support dual core processors - it is just too old and only supports Celeron M or Pentium M processors. Also I'm fairly sure it cannot support a 667MHz FSB.
http://www.intel.com/content/www/us/en/chipsets/mainstream-chipsets/mobile-chipset-915gm.html
http://ark.intel.com/products/chipsets/19210
I think the 945 was the first chipset to support Dual Core.
