Sound keeps dissapearing
len112
i have a sony vaio Pcv rs704 with a recurrent problem with sound everything works normally then sound disappears , every type of sound cd , music file , system sounds . If i turn up the volume from the keyboard I can hear speaker hiss , so the speakers are working , also Itunes won't play at all ie the any music files won't run ( even though no sound , the progress indicator for file playing doesn't move ) while this sound problem persists . I can usually fix the problem with a reboot at which point system sounds return as the computer goes into shutdown so I think it might be a software conflict ,though this fault has persisted after several system reinstallations
16 REPLIES 16
VAIOFAN
Yep i got PCV - RS502 and mine done the same thing as urs, Mine cuts out if i play 2 music files at the same time or if i open files to fast like put one film on qrick then change it fast.
Than the sound goes off!
So i have to reboot my computer switch on the sound.
But its not done it sence thow i like to no what ive done right because now i can play 2 music files at the same time.
Weird......
Paul
kee-lo_
I remember someone else having this, but I'm scratching my head to find the solution...
len112
I continue to have this problem , when the sound dissappears I've noticed that windows media player video files won't run properly either , other than the total lack of sound the video playback it pauses and restarts and stops , does this perhaps narrow down the cause of the problem , please help
kee-lo_
Press ALT+CTRL+DEL and go to processes then double click on the CPU tab. Is wmplayer.exe using a lot of cycles?
VAIOFAN
Im using Windows media player version 10 and i done what you said Kee Lo!
And i stuck on a movie on and i check my processes and it was on 3 of usage.
So mine wasnt bad!
Thanks for your help.
kee-lo_
Ahh I meant once Windows Media Player was closed (called a lingering process)
VAIOFAN
sorry if i mis understood you, yeah your right Kee Lo, i closed down the program and its still running and using more usage! goes up to around about 15 approx! now i end the proccess!
Why is this happing?
Paul
kee-lo_
Usually bad codecs.
If you end the task do you get your sound back?
VAIOFAN
Yeah, it happend tonight, i done what you said and the sound is back!
So now i dont have to restart my computer no more, hip heee:smileygrin:
Thanks mate,
Paul
