Sound keeps dissapearing
len112
i have a sony vaio Pcv rs704 with a recurrent problem with sound everything works normally then sound disappears , every type of sound cd , music file , system sounds . If i turn up the volume from the keyboard I can hear speaker hiss , so the speakers are working , also Itunes won't play at all ie the any music files won't run ( even though no sound , the progress indicator for file playing doesn't move ) while this sound problem persists . I can usually fix the problem with a reboot at which point system sounds return as the computer goes into shutdown so I think it might be a software conflict ,though this fault has persisted after several system reinstallations
16 REPLIES 16
kee-lo_
No problem.
Was it a DivX?
If so reinstall it, or better get v6
VAIOFAN
yeah! i downlaoded the version 6.0!
Its all better now!
kee-lo_
:cool:
VAIOFAN
:laughing: :laughing: :laughing: :laughing: :laughing:
nice smilie Kee lo!
len112
I followed those instructions but could not see wmplayer.exe in task manager , however have downloaded Divx 6 and hope it makes a difference , Thanks for your help , incidentally if not windows media player , what else could be causing it ?
kee-lo_
What program are you using when this happens?
len112
It happens randomly , I can be surfing the internet and suddenly realise I have no system sounds , or it can happen at anytime , It never happens in the middle of playing a video or audio file , I only usually realise it's occurred If I try to play a file and then the sound doesn't appear
