svchost.exe removal of...trojan/virus
DLJ
None of the usual replies please, tried them all. No prog. identifies it.Trendmicro sysclean tells me its unscanable - access denied etc.. It has encoded the prefetch file and other system files.Can anyone analyse it and come up with removal prog? Will supply copy.
Thanks.
DLJ
mathrobe
hi dlj.
i had a problem with a trojan attached itself to the svchost.exe. i tried to get rid of it with Norton, AVG, Ad-Aware but could not get rid of it after a lot of searching i found tool called
Microsoft Antispyware Beta1, which i downloaded and installed
i ran the programme and it found the trojan and removed it for me with no trouble. even though it is only a trial version it seems to be a good tool,when the finished version is available i shall defintely be buying it. i hope this helps you
kee-lo_
It's not a trial it's a beta and Microsoft said it'll be free when final
