Vaio Duo 13. Anyone updated to Win 10 sucessfully?
homeyjay
After a few years of looking, I finally picked up a nice Vaio Duo 13. I just spent a day doing all the updates that are available to take it to Win 8.1 but would really like to go to Win10. Is it possible to update this PC to Win10 and still have everything working? Has anyone done it?
I've downloaded the Win10 update tool but it fails, saying that I don't have the newest version of Vaio update. I can't find any newer updates..
Any tips would be gratefully received!
Tags (2)
12 REPLIES 12
homeyjay
Ok, ive done this but now I seem to have an older version of the driver installed!
I installed the default Win10 driver and then asked it to update the driver and it downloaded and installed ver 5.93.102.10
I think this is an older version but I'll shut the laptop down and see what happens!
Tags (1)
homeyjay
UPDATE
Now working properly and not cutting out after sleep!
Thanks for the help Manolo!
Seems that downgradng the driver has done the trick. Will report back if there are any other issues but far, Win 10 is just fine on the Vaio Duo.
Marino.Manolo
Genius
I'm sorry for my delayed... But now the situation always is fine...
Your welcome... -)
Manolo
