Hi there,
Just a quick question - the power supplt for my vaio (the box) gets really really hot, it almost burnt me when I touched it the other day - is this a normal occurance or should I be concerned?
Regards,
Matt
I boutgh sony vaio fe21h 2 days before - you know I have some problem.. is it seriosuly you think?
If it's burning you as you say then that does need to be investigated
