Vaio SZ2XP Battery Position
oceanboy
I received my Vaio SZ2XP from Sony yesterday. Everything works fine expect one thing, and that's the battery. The battery just doesn't sit properly into the slot. I have personally measured it, there is actually a 1mm gap between the battery and the slot when it is installed. They are loose such that the moment when I turn it upside down, it will make noise, as the result of the gap.
Is that normal and is it designed like that?
Thanks a lot for your time guys. I really appreciate it. :smileygrin:
EDIT : Sry, I didn't search before. Several VAIO models also have this kind of problem. So I guess I just have to be patient with the "clonk" sound.
24 REPLIES 24
MarkErickson
Hi olilloyd,
No, don't do that. The program 'Setting Utility Series' is what I uninstalled by accident when I meant to unisntall 'Private Disk'. Doing a system restore returned 'Setting Utility Series'. I then uninstalled 'Private Disk' successfully.
I don't know why yours hasn't uninstalled properly, are you sure you uninstalled the right thing? (which was my mistake)
Mark
oceanboy
The program after SafeGuard is Setting Utility Series. By they way, I wanna uninstall the system with the clean Windows. All the preinstalled apps make the windows run to slowly. Hoepefully I won't miss any drivers that can cause one hardware to malfunction. Thanks.
Thalamus.
Champion
Hi oceanboy,
If you are going to install a clean copy of Windows XP, make sure you have created at least 2 set of Recovery disc's..
These will be required as you will need to restore the original operating system should you need to make a warranty claim via Vaio-Support...:smileywink:
oceanboy
Yeah, you are right, Thalamus, but I found that so many people having difficulties of creating a recovery CD. I might try to do it later today.
By the way, I just found out that my battery performance is a bit strange. If I charge my battery to 100%, then plug the AC power off, and always leave my machine on until it discharge to let say 6%, the battery works normally (the machine works for at least 4 hours). But if I charge it to 100%, use it for 30mins until let say 85%, then I turn the machine off for 1 day, the next day when I turn it on, the battery drops to 65%. If I use it again for 30mins until let say 50%, then turn it off again for 1 day, the next day, the battery drops to 30%. Why is it behaving like that? Any idea, guys?
So the main problem here is only occur when I turn my machine off.
Thanks a lot, dude.
oceanboy
Hi, sry for double posting, but can somebody help me with my problem above? Thanks.
