I need to know if VAIO VGN-TZ21MN has a motion eye camera incorporated... I'm asking because a can't find it...
Solved! Go to Solution.
Hi pilarbaylina and welcome.
Yes your VGN-TZ21MN does have a webcam.
Check in Device Manager - Imaging Devices. Does it show a 'Sony Visual Communication Camera VGP-VCC7' as being installed and working? If not you need to install the camera driver.
Also do you have the program 'VAIO Camera Capture Utility? If yes, try opening it.
For the camera to work you need the following to be installed: -
1. Camera Driver for VGP-VCC7 Webcam
2. Vaio Camera Utility
3. Vaio Camera Capture Utility
You will find 1. in the Original Drivers Package and 2. & 3. in the Original Utilities Package. These can be downloaded from here: -
http://www.sony.co.uk/support/en/product/VGN-TZ21MN_N/updates
