Can someone tell me how can I update my video card driver to version 12.3.I was trying to do it by Amd site but it make error that My software/hardware is incompatible on my computer.
Sorry for my English.
Message was edited by: Xarels
Solved! Go to Solution.
Hi Xarels.
The ATi laptop drivers will not install as the manufacturer (Sony) is responsible for releasing driver updates.
In reality, Sony only rarely update drivers - and then only to fix a specific problem - so you should contact Vaio Support if your current driver is causing a problem.
