VPCS11X9E HDMI stopped working
amit89
Hi, recently my HDMI port stopped working, and I can't see "HDMI port" or similar anywhere in the device manager. I wanted to check it wasn't just a driver issue before I took it somewhere to get repaired and have been checking online to find the driver. Unfortunately It isn't too clear on the download section of the website which one I would actually need to download in order to reinstall this driver. Can anyone help?
Regards
Alex
Sadly, it does sound like it needs looking at by an engineer.
:slight_frown:
4 REPLIES 4
Hi Alex and welcome.
HDMI output will be controlled by the Intel HD Graphics Driver.  Have you installed the update available on the download page for your Vaio here: -
http://www.sony.co.uk/support/en/product/VPCS11X9E_B/updates
Click on the Latest Downloads for Windows 7 and scroll down to the Driver section where you will find the Intel Driver version 8.15.10.2040.
:thinking:
amit89
Hi thanks for the reply.
I actually downloaded that a few days ago and tried to install it. I guess it didn't install as it says a version ending in .1995 in my device manager. I will try to dl and install it again thanks.
If it did not fix the issue and the HDMI remains unresponsive could this be something like a loose cable or anything in your opinion?
Alex
amit89
Ok the driver is now the latest one but it still isn't recognising when I plug in the HDMI lead, I guess it is a physical issue?
:slight_frown:
